iamthequinn Posted January 7, 2018 Share Posted January 7, 2018 Hi all, can anyone confirm what the correct type of diagnostic reader I should get for my Mk3 TDCI Mondeo (facelift version). I read elsewhere that it was OBD2 but this doesn't seem to be the case... Any info gratefully received. Quote Link to comment Share on other sites More sharing options...
Ghia15 Posted January 7, 2018 Share Posted January 7, 2018 All cars sold have an obd 2 port. They came in around 1997/98 I believe. In my mk4 it is to the right of the steering wheel in a little compartment behind a cover. Think it was in a similar place on my mk3 as well. My dads 99 Volvo has one as well. Depending on what you want to read a generic fault code reader will tell you how the engine is running, faults and any stored codes on the memory. It should allow you to clear any old codes as well once any repairs have been done. I have just got a generic one but haven’t used it yet. Hope this helps Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 7, 2018 Share Posted January 7, 2018 ‘Obd2’ wasn’t mandatory until 2001 for Petrol and 2004 for diesel. Some cars were fitted with it before this but otherwise it would be obd1 Quote Link to comment Share on other sites More sharing options...
iamthequinn Posted January 7, 2018 Author Share Posted January 7, 2018 Thanks. Ghia15, I know where the port is: when I plugged it in this morning the software said it couldn't access the ECU. The manual says that's because the car isn't OBD2. Stef123 - yep, I saw that on the interweb before I bought it: I assumed that as mine was a facelift Mk3 on an 04 plate it would be compatible, but looks like I was wrong. I've also (subsequently) seen some say that they've got later Mk3's which also aren't OBD2, some talking about CANBUS? Just want to make sure I get the right one next time Quote Link to comment Share on other sites More sharing options...
iamthequinn Posted January 7, 2018 Author Share Posted January 7, 2018 Found this on TalkFord.com which really doesn't help. Maybe I should ask a different question: those who have a Mk3 TDCI, what diagnostic scanners do you use? Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 7, 2018 Share Posted January 7, 2018 I use a bluepoint one, works perfect on my 2006 mondeo 1 Quote Link to comment Share on other sites More sharing options...
pragmatix Posted January 7, 2018 Share Posted January 7, 2018 I used Forscan (free download)and a modified elm connector http://www.ebay.co.uk/itm/Black-USB-Modified-ELM327-Elmconfig-Forscan-Ford-Focus-Mondeo-Kuga-S-Max-/181457166623 1 Quote Link to comment Share on other sites More sharing options...
iamthequinn Posted January 7, 2018 Author Share Posted January 7, 2018 That looks ideal! Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted January 8, 2018 Share Posted January 8, 2018 On 07/01/2018 at 8:12 PM, iamthequinn said: That looks ideal! Just a quick note, if you referring to the post by Pragmatix he has a MK4 and not a MK3 Mondeo which is a very different beast electronically. Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 8, 2018 Share Posted January 8, 2018 I use forscan too on my mk3, no issues there. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted January 8, 2018 Share Posted January 8, 2018 18 minutes ago, 1979Damian said: Just a quick note, if you referring to the post by Pragmatix he has a MK4 and not a MK3 Mondeo which is a very different beast electronically. Works with a mk3 been using it for years , in fact works with any Ford , with an OBD port Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted January 8, 2018 Share Posted January 8, 2018 7 minutes ago, pragmatix said: Works with a mk3 been using it for years , in fact works with any Ford , with an OBD port I was thinking more from a cable perspective with the Op saying that it's not ODB2 on his car, I've not fiddled with a non-ODB2 car though so I'll bow to your superior knowledge Quote Link to comment Share on other sites More sharing options...
nicam49 Posted January 23, 2018 Share Posted January 23, 2018 Hi, there was an issue with early facelift Mondies that altho' they had single-box brains they weren't OBD11 compliant. (Well, not an issue...that's how they were) I've got a 2002 Mondy, which has the 2-box brain, separate ICU and ECU, and to reprogram my injector codes, I had to buy a FORDIAG from the Czec Republic cost around £80, but I do believe a UK firm called tunnelrat electronics now do a much cheaper one that works with non-OBD11 Mondies. Check out their site: https://tunnelrat-electronics.fwscart.com/ Quote Link to comment Share on other sites More sharing options...
RexMagna Posted 3 hours ago Share Posted 3 hours ago Did anyone tried a bluetooth obd2 adapter and connected it to ECU of a mondeo mk3 tdci car? If you did, please tell us wich model you used. Quote Link to comment Share on other sites More sharing options...
nicam49 Posted 11 minutes ago Share Posted 11 minutes ago Check out Tunnelrat electronics and drop them a line . But: I see you're not in UK, and I don't think they sell outside UK. 1 Quote Link to comment Share on other sites More sharing options...
Jimpster Posted 5 minutes ago Share Posted 5 minutes ago 4 minutes ago, nicam49 said: Check out Tunnelrat electronics and drop them a line they sell the pre-modified ELM with the high/low switch, i believe the V-linker is self switching Unofix is the man to ask on all things Forscan Quote Link to comment Share on other sites More sharing options...
