DjRathbone Posted February 24, 2023 Share Posted February 24, 2023 I am hoping for someone's assistance here. Following this forum post, I decided to take the plunge, I bought a steering wheel with cruise control buttons and a Vgate vLinker FS USB (As recommended by the ForSCAN website) and got a 2 month free licence for ForSCAN. I have a 64' Ford Focus 1.5L Petrol Zetec S Mk3.5. I followed a tutorial on YouTube regarding the ForSCAN side of things, connected to the vehicle, saved a profile of the vehicle, went to the DTC, deleted the errors, turned the ignition off and then back on and rescanned, went to config and programming, opened BCMii Central configuration, turned ignition off as prompted, searched for cruise control, enabled cruise control, then searched for adjustable speed limiter, enabled that through engineering mode, saved a copy of the configuration, then clicked write, turned ignition on as prompted, loaded blocks and blocks programmed successfully, stopped service procedure. The next step was to open the PCM Module Configuration but I did not have that option without (AS BUILT Format) next to it. And therefore I have been unable to change the Adjustable Speed Limiter (to With ASL, Less ISA) and Cruise Control (2 - Cruise Control). HOWEVER At this moment in time, cruise control and adjustable speed limiter work absolutely fine like a dream, I have no issues apart from in the DTC I have the following error that I cannot seem to get rid of in the IPC: Code: U2101 - Control Module Configuration Incompatible Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Panel Control Module My question is, is this a problem, or can I carry on about my business, it doesn't appear to have affected the vehicle in any way, drives the same, no error lights on the dash and cruise control/adjustable speed limiter are working as expected. If it IS an issue, how would one deal with this? Quote Link to comment Share on other sites More sharing options...
allsomatt Posted March 17, 2023 Share Posted March 17, 2023 On 2/24/2023 at 4:08 PM, DjRathbone said: I am hoping for someone's assistance here. Following this forum post, I decided to take the plunge, I bought a steering wheel with cruise control buttons and a Vgate vLinker FS USB (As recommended by the ForSCAN website) and got a 2 month free licence for ForSCAN. I have a 64' Ford Focus 1.5L Petrol Zetec S Mk3.5. I followed a tutorial on YouTube regarding the ForSCAN side of things, connected to the vehicle, saved a profile of the vehicle, went to the DTC, deleted the errors, turned the ignition off and then back on and rescanned, went to config and programming, opened BCMii Central configuration, turned ignition off as prompted, searched for cruise control, enabled cruise control, then searched for adjustable speed limiter, enabled that through engineering mode, saved a copy of the configuration, then clicked write, turned ignition on as prompted, loaded blocks and blocks programmed successfully, stopped service procedure. The next step was to open the PCM Module Configuration but I did not have that option without (AS BUILT Format) next to it. And therefore I have been unable to change the Adjustable Speed Limiter (to With ASL, Less ISA) and Cruise Control (2 - Cruise Control). HOWEVER At this moment in time, cruise control and adjustable speed limiter work absolutely fine like a dream, I have no issues apart from in the DTC I have the following error that I cannot seem to get rid of in the IPC: Code: U2101 - Control Module Configuration Incompatible Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Panel Control Module My question is, is this a problem, or can I carry on about my business, it doesn't appear to have affected the vehicle in any way, drives the same, no error lights on the dash and cruise control/adjustable speed limiter are working as expected. If it IS an issue, how would one deal with this? I may have potential answer for you as I am trying to do the same except with a 2017 1.5 TDCI Zetec. I have yet to access FORscan however I have been checking the wiring of the steering wheels. Something has come to my attention in doing this... It appears that there a two different layouts for the cruise control buttons, the Cruise on and LIM buttons swap with RES & CAN buttons. Seen some photos on eBay and the wiring does appear to be slightly different as well. Auto-trader cars in my yr group vary wildly too but this can't just be a coincidence surely? 1 Quote Link to comment Share on other sites More sharing options...
allsomatt Posted March 18, 2023 Share Posted March 18, 2023 On 3/17/2023 at 10:50 AM, allsomatt said: I may have potential answer for you as I am trying to do the same except with a 2017 1.5 TDCI Zetec. I have yet to access FORscan however I have been checking the wiring of the steering wheels. Something has come to my attention in doing this... It appears that there a two different layouts for the cruise control buttons, the Cruise on and LIM buttons swap with RES & CAN buttons. Seen some photos on eBay and the wiring does appear to be slightly different as well. Auto-trader cars in my yr group vary wildly too but this can't just be a coincidence surely? **UPDATE** Have access to a computer with FORscan, can confirm my Mk 3.5 Face Lift TDCi 2017 Focus has PCM module access, I believe Petrol variants do not need to access the PCM unlike Diesels will be fitting the Cruise Steering Wheel and Programming either today or Sunday will post an update on the results. Quote Link to comment Share on other sites More sharing options...
allsomatt Posted March 18, 2023 Share Posted March 18, 2023 SUCCESS! INSTALL/UPGRADE COMPLETED CAN CONFIRM FULLY FUNCTIONAL CRUISE CONTROL AND SPEED LIMITER WORKING! All for under £100.00 Fully OEM vs Third Party who wanted £500+ I cannot confirm if this guide will work for everyone but having spent a month researching then performing the procedure it has worked for me. **Try this at your own risk** I have attached a full PDF guide to my process, please ensure you buy a genuine V-Linker Cable, absolutely recommended. Good Luck. **FINAL POST REGARDING CRUISE INSTALL** Guide Cruise Control Install Ford Focus_01.pdf 3 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 18, 2023 Share Posted March 18, 2023 49 minutes ago, allsomatt said: SUCCESS! INSTALL/UPGRADE COMPLETED A very good result well done. Now for the next upgrade convert it to Adaptive Cruise Control 🤣 2 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted March 18, 2023 Share Posted March 18, 2023 will be doing his on may. think i will need alot of luck 😄 1 Quote Link to comment Share on other sites More sharing options...
Mada Posted November 18, 2023 Share Posted November 18, 2023 Hello, does anyone have UDCS in the vicinity of Essex/London and could enable cruise control for my 1.5 TDCI C-MAX please? Happy to pay! Quote Link to comment Share on other sites More sharing options...
froggy8 Posted November 18, 2023 Share Posted November 18, 2023 I just did this on my brother on laws car, couldn't believe how easy it was, only took something g like 30 mins to program it. Quote Link to comment Share on other sites More sharing options...
ChrisCh Posted September 18 Share Posted September 18 I've got UCDS and am happy to activate OEM cruise control on a Focus or C-Max (I've done it on over 5 cars now). Should also work on other Ford models. I'm based in SE London. Just send me a message. Quote Link to comment Share on other sites More sharing options...
