Ford Fiesta MK7.5 Rear washer jet spray missing window! Please Help!
Branchinho
 Share
Hi!
I recently added the large rear wing spoiler to my standard 14 plate fiesta. However whenever I go to wash the rear screen with my wiper the jet shoots most of it onto the floor or lower bumper of my car. This is because I have essentially pushed out the light bar because the spoiler is bigger. I have tried moving the little red washer jet but it won't budge and only stays in the one position. I doubt other fiestas like st versions have the same problem with their rear washers. Can someone please tell me if I'm missing something? Or even better if someone has also done this and has the same problem as me, thanks! Any help is appreciated!
Link to comment
My Fiesta had the standard spoiler and had a genuine ford zetec s spoiler purchased & painted and I fitted the spoiler myself using the original brake light but with the supplied extensions for the washer jet pipe, washer jet hits the top of the window just above the wiper blade.
Link to comment
The only extension was a longer black piece of tubing. Should I have had something else like a newer red piece which is where the water comes out? Thanks
Link to comment
hi. im having the same problem the tube extension cant have anything to do with the spray direction ..i will get it sorted soon.let me know if you sort it out first. cheers
Link to comment
Here we go,  my sons pall call around today with his fiesta with the st spoiler on., on inspection the washer was the same but it was black not red. also on my light fitting the washer jet was glued in and his was not. Then we looked at the spray .The slot on the st is in a total different position. so we decided to have a go at releasing the red jet unit. After a bit of gentle   movement it broke free so i was able to remove it . Then i copied and marked were the slot is on the st one is on mine a few swipes with the junior hack saw just to score it .next get a small flat blade screwdriver the same size as the original slot and heat it up with a lighter and gently press it into the hacksaw mark taking time not to make it to large. then fill the old hole up with small amount of silicone and its job done. Thanks scot for your help.
  • Like 2
Link to comment
That's seems like the answer! Cheers I'll have to try that.. will be harder to copy the exact positioning but I get the idea! Thanks man!
Link to comment
if you can get a look at one you will be surprised how close the slot is to the lens .just a few mm up. mark it up when it is in place then remove it to cut and and hot screwdriver.
also put the cold screwdriver back in when you fill the old slot don't put to much silicone in.  also keep thinking about the angle when you use the screwdriver .good luck.
  • Like 1
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
  • Insurance
  • Support
