hk Posted January 31, 2016 Share Posted January 31, 2016 Hello all, A 2007 Fiesta is in need of TLC after having an argument with some wildlife on the dual carriageway I'm checking the paint codes, and I'm not liking what I'm seeing: If I understand the paint code system correctly, this VIN shows the paint code to be V5.. which would be Jewel Green introduced in 2005. As the more observant of you may have noticed, the paint around the VIN plate doesn't look particularly green... Leaving that particular issue to one side, any idea what the correct paint code is for this? I've definitely seen other Fiestas this colour so I'm fairly sure it is a standard colour. Cheers, hk Quote Link to comment Share on other sites More sharing options...
paul950 Posted January 31, 2016 Share Posted January 31, 2016 Type your registration into Ford Etis and it will tell you what the paint colour was when made at the factory https://www.etis.ford.com/vehicleRegSelector.do;jsessionid=F0DBB5437C541A27432B64D2CB457D17.eccvas502 1 Quote Link to comment Share on other sites More sharing options...
hk Posted January 31, 2016 Author Share Posted January 31, 2016 Hi Paul, Thank you very much- that is exactly what I was after. It is coming up as Amethyst which (after a quick google search) matches the colour of the car. The VIN also matches. Which now raises a really interesting question... why does that plate show a different paint code? I'd understand it if ETIS was showing something different like colour, registration or VIN but it doesn't. But many thanks once again 1 Quote Link to comment Share on other sites More sharing options...
firefighter Posted January 31, 2016 Share Posted January 31, 2016 My car is panther black ,what is the colour code here Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 31, 2016 Share Posted January 31, 2016 1 Quote Link to comment Share on other sites More sharing options...
Russ Posted January 31, 2016 Share Posted January 31, 2016 Ford colour codes 2002 2012 http://www.maxmeyerplus.co.uk/userfiles/colour_support_pdf/136931658125680600136931658163429mm_ford-colour-codes_2002-to-2012.pdf 2 Quote Link to comment Share on other sites More sharing options...
rich67 Posted August 3, 2016 Share Posted August 3, 2016 so my code is c6 woild that be ocean blue ? Quote Link to comment Share on other sites More sharing options...
Russ Posted August 3, 2016 Share Posted August 3, 2016 If it's a 2001 Ka the code c6 is Moondust silver. http://de.nexaautocolor.com/media/215333/11-nexa_autocolor__ford_color_codes_2001_bis_2011.pdf Quote Link to comment Share on other sites More sharing options...
