Accident Damage
Gham05
 Share
Got a bit of a dent in my fiesta! Still waiting back on hearing from Ford with a estimation on the extent of the damage! What do you people think, write off or fixable?
post-40273-0-56751700-1359062404_thumb.j
post-40273-0-87232300-1359062412_thumb.j
post-40273-0-06522200-1359062425_thumb.p
post-40273-0-87882900-1359062436_thumb.j
post-40273-0-09647200-1359062447_thumb.j
post-40273-0-29586100-1359062454_thumb.j
Link to comment
Ouch! that looks nasty, how did it happen? I've noticed you say it's a Zetec S, but the front bumper is from a Zetec?
Link to comment
Turning around in a car park, turned right and ended up going sidewards into a lamp post! Absolutely gutted, just hoping it's not a write off! Really? It's definitely a Zetec S
Link to comment
Too soon for the "It'll buff out" joke??
Seriously tho glad your ok... as for writeoff/fix... without knowing whats happened under the bodywork I doubt any of us can say!
Link to comment
Nipped into Halfords after, can of moondust silver and a tube of t-cut, should have it looking like new in no time ha ha! That's what i thought the response would be. Just hoping, it's minor damage under the body work. Main concern was the inner wing (i think that's what it's called! correct me if i'm wrong - to the right of the battery, seen in the 3rd image) Also how close the wheel is to the door hinge in the 5th image.
Link to comment
Ah gotcha, Chrome grill was an extra! Love this car to bits, hoping it can be fixed, even it does mean i lose my ncd
Link to comment
Hard to say, I'm on the fence about this, as far as body work is concerned, you need a new bumper, wing and bonnet, headlight and god light, with a repair on the door, what I can't quite tell is the damage to the strut tower, and the pieces the slam panels attach too, also can't tell what chasis damage has been done. I'm sort of migrating over to a cat D personally.
Link to comment
Was afraid it would be a cat d, sent a few of these images to a friend and he's said he same! What happens in the instance of a cat d, will the insurance essentially write it off completely?
Link to comment
Yes, it's an insurance write off. Can be rebuilt if whoever gets it off the insurance company deems it worth while to them, in which case it'd be indicated in the log book and then resold. If it's not worth it, which I'd kind of say isn't, it'd go to a breakers and has a tiny chance of being rebuilt if they have the parts but if it's damaged the main body of the vehicle it wouldn't be, more likely broken and the Shell crushed. I work at a breakers and see this all the time.
Cat C and D are able to be repaired, think C has to be proven roadworthy whereas D can just be fixed and sold on. Cat B has to be broken (which is P*** annoying! At work we have a mint Focus ST2, not a mark on it and is cat B due to flood damage, runs beautifully and is fine inside, not a single thing wrong with it; and today a Golf GT with 800 miles on it, cat B for same reason and mint -.-), then cat A which has to be crushed.
Also, doesn't matter if someone dies in the car, can be a cat D still lol.
Link to comment
I'll let you know the outcome from the insurance, Was hoping it wasn't going to be a write off, but had doubts! Just need to see what happens next and if it's declared a write off, what they'll pay out. Pretty gutted!
Link to comment
If it's a cat C or D then it's repairable but the Insurance Company may say that it's not economical to do so.
That inner panel can be pulled straight on a jig and bodywork can be repaired.
My car is a 2007 and the insurance company paid up for £1500 of damage caused by a prat wheelying motorbike into mine, if the bill is less than £3000 i reckon they'll cough up, any more than that and it's doubtful tbh.
Link to comment
Depends how they died. Any blood drops in it make it Cat A due to biohazard to potential future ursers.
and to confirm what was already said, CatC means it needs a VIC check done once its repaired for anti fraud measures and as a mini MOT. Any Vosa station can do it, takes about 30 minutes. If you retain a CatC total loss, you'll be issued the paperwork by the insurer, but expect to lose a large chunk for the TL payment that we'd get for scrapping the vehicle.
Link to comment
All sorted lads, £4000 grands worth of damage, quoted by Ford, wishbones, track rod ends, suspension to be reaced and all the damaged body work
ON + OFF CHASSIS JIG
R + R FRONT BUMPER
INCLUDES: R + R HEADLAMPS
REPLACE FRONT BUMPER BAR
(WITH BUMPER BAR REMOVED)
R + R LOWER RADIATOR AIR DEFLECTOR
ADJUST HEADLAMPS
RENEW L/HEADLAMP (REMOVED)
RENEW L/WING
INCLUDES: WHEELHOUSE LINER R + R
NOT INCLUDED: SIDE WINDOW
A-PILLAR R + R (NOT NECESSARY)
BONNET EDGE SEALANT
REPLACE BONNET
INCLUDES: REMOVE/REFIT BONNET; FIT AND
SET CLEARANCES; REFIT PARTS
REMOVE/REFIT LH BONNET HINGE
(WITH BONNET REMOVED)
R + R WASH/WIPE BOTTLE
RENEW PARTIAL L/APRON
R + R L/F DOOR TRIM
R + R L/F DOOR HANDLE
R + R L/FRONT DOOR WINDOW SEAL
R + R L/OUTER MIRROR
R + R CENTRAL ELECTRIC
R + R LEFT FRONT WHEEL
DETACH + REFIT SUSPENSION PARTS
RENEW LEFT FRONT WHEEL
(WHEEL REMOVED)
INCLUDES: BALANCE AND RENEW VALVE
REPLACE LH PIVOT BEARING
(WITH PIVOT BEARING REMOVED)
R + R LEFT SPRING STRUT (WHEEL REMOVED)
INCLUDES: R + R PIVOT BEARING
REPLACE LH SUSPENSION STRUT
(WITH SUSPENSION STRUT REMOVED)
INCLUDES: REFIT PARTS
R + R L/F CONTROL ARM
DOES NOT INCLUDE: CHECK + ADJUST FRONT
AXLE ALIGNMENT
VEHICLE ALIGNMENT CPL
ADJUST FRONT TOE
REPAIR L/S-MEMBER/STAY PNL
REPAIR L/F DOOR
PULLING FRONT PANELS
MEASURE CHASSIS
BONNET NEW PART PAINTING
L/F WING NEW PART PAINTING
FRONT BUMPER NEW PART PAINT K1R
FRONT SKIRT NEW PART PAINT K1R
L/F DOOR REPAIR PAINTING <50%
LEFT A-PILLAR REPAIR PAINTING <50%
R/F WING SURFACE PAINT
L/S-MEMBER/STAY PNL SURFACE PAINT
HINGE BONNET
CLAMP MARKS DRESS
PREPARATION FOR PRE-PAINTING
FRONT BUMPER
FRONT SKIRT
BONNET
L/BONNET HINGE
LEFT HEADLAMP ASSY
L/F FOG LAMP
L/F FOGLAMP FRAME
L/F WING
L/WHEELHOUSE Shell
LWR AIR GUIDE PANEL
L/F STAY PANEL REINF
L/F W-HOUSE FILLER
COWL PANEL COVER
WASHER CONTAINER
WASHER RESERVOIR CAP
L/F TRACK CONT ARM
L/STEERING KNUCKLE
L/F SHOCK ABSORBER
L/F WHEEL
L/F TYRE -
MODULE BOX HOUSING
MODULE BOX COVER
SUNDRY PARTS
Everything quoted
Link to comment
Never heard of insurance paying out that much for something like a Fiesta >_>
Link to comment
Is that 4000 , that the insurance have agreed to pay ? , wow big bill , i bet if you sourced the parts yourself it would be at least half that price.
Link to comment
Thought exactly the same, pretty shocked to too be fair, would have cost much less if it was done independently. Yeah Ford assess the damage and decide whether it's economical to repair it in, and then authorise it themselves. And as far as i know, the insurance just pick up the bill at the end
Link to comment
Pretty much :) Authorised Repairers will do an Audatex report, auth if it's under 66% of total value of the car, invoice over a Shell to the insurer and the claims support team will issue payment.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
  • Insurance
  • Support
