Valdys Posted Monday at 11:35 PM Share Posted Monday at 11:35 PM Hi all, There is no sound in the front speaker passenger side.I checked the speaker the sound is there and it works.But when I connect it to the front passenger side it doesn't work.The other three Speakers work without problems.Any ideas what's wrong?Thank you. Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted Tuesday at 09:20 AM Share Posted Tuesday at 09:20 AM You've checked the speaker on another door you mean? And it works? You probably have a broken wire in the door harness, probably in the flexible joint from the door to the A-Post 1 Quote Link to comment Share on other sites More sharing options...
Valdys Posted Tuesday at 04:18 PM Author Share Posted Tuesday at 04:18 PM Hi, yes, I checked the speaker in the other door and it works without a problem. Probably the best option is to go to an electrician, because I don't know where the problem is. Quote Link to comment Share on other sites More sharing options...
StephenFord Posted Tuesday at 05:08 PM Share Posted Tuesday at 05:08 PM 50 minutes ago, Valdys said: Hi, yes, I checked the speaker in the other door and it works without a problem. Probably the best option is to go to an electrician, because I don't know where the problem is. How did you format your reply like that? I've tried to replicate, but can't 🤣 Quote Link to comment Share on other sites More sharing options...
