Chris2674 Posted 9 hours ago Share Posted 9 hours ago Hi, I have a 2017 2.0TDCI S-Max that has been flashing up warnings for the ABS, Park Assist, Traction Control, Hill Start Assist, and Electric Handbrake. ForScan shows codes for communication errors on ABS, Park Assist and Parking brake modules, front left and right ABS sensors, and steering wheel position. I have checked all the sensors etc but am slowly coming to the conclusion it is the ABS module or the wiring to it. I hear the modules are £600+ and need programming to the car. My next task is to locate the ABS module and check the wiring to it. I believe this is behind the battery? Anyone else have these faults before? Thanks Quote Link to comment Share on other sites More sharing options...
unofix Posted 5 hours ago Share Posted 5 hours ago 3 minutes ago, unofix said: 2017 vehicle will be due (overdue) a new battery if it is still on the original factory fitted. Low system voltage can cause all of the faults that you have. Quote Link to comment Share on other sites More sharing options...
