IrishMk3 Posted October 8 Share Posted October 8 So having the condensation issue with the front passenger headlight and ive done everything to try fix it bar taking the thing completely apart. Ive dried the inside, resealed with silicone, removed bottom bung for more airflow but still comes back. Been having a look around for a new headlight (new and used) and was curious about the OEM numbers. My part number is BM51-13W030-BH but when is search it up i gets results for not only that but part numbers that end in DF or PB or that have 29 instead of 30 for example. Question is, would this parts work and fit even though the numbers are slightly different? Quote Link to comment Share on other sites More sharing options...
Bol Posted 3 hours ago Share Posted 3 hours ago What is exactly the issue? Any photograph? Quote Link to comment Share on other sites More sharing options...
troy45 Posted 2 hours ago Share Posted 2 hours ago I think you’ll find the 29 and 30 numbers relate to LHS and RHS headlamps. But you need to match the correct first letter of the part number suffix, i.e B as this is the specific spec for the lamp. Ideally BH or a later letter at the end as these go up each time an engineering change is made to the parts. You may get away with earlier letters below H level but not guaranteed 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted 2 hours ago Share Posted 2 hours ago eBay item number 1509822771 - Part BM51-13W030-BH £80 Free P&P https://www.ebay.co.uk/p/1509822771 Quote Link to comment Share on other sites More sharing options...
