NikkiT Posted 15 hours ago Share Posted 15 hours ago Hi there! I changed the battery in my key fob yesterday as it was saying it was low. Is there anything I’m meant to do afterwards as now it’s not working at all 🤦🏻♀️ Many thanks for any help Quote Link to comment Share on other sites More sharing options...
StephenFord Posted 15 hours ago Share Posted 15 hours ago 31 minutes ago, NikkiT said: Hi there! I changed the battery in my key fob yesterday as it was saying it was low. Is there anything I’m meant to do afterwards as now it’s not working at all 🤦🏻♀️ Many thanks for any help Check it's the right way up Check you have removed the clear protective film on it so it makes a good contact with the fob (use nail polish remover or similar) Check that it is touching the metal tabs of the battery holder. Check the battery is good and pushing out 3.3v (just because it's new, don't assume it's good) Needs no programming, should work straight away... 2 Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted 15 hours ago Share Posted 15 hours ago Hi Nikki, Stephen's covered all the points there, but just to amplify: - Residue left after removing any film or sticker is not always obvious so do clean it as suggested - "dud" batteries are not uncommon even with well known brands from reputable sources. Several instances of fake Duracells have also been reported. 1 Quote Link to comment Share on other sites More sharing options...
