Automaticsford Posted Sunday at 01:22 PM Share Posted Sunday at 01:22 PM I've got a Ford Focus Ecoblue 2.0 diesel 2019 MK4, Prior to June the car was working absolutely fine no issues after coming back from holiday now the car doesn't start and battery is drained, replaced the battery and now the car has various error faults, cleared them all down and have a few low voltage ones and some U codes with loss communications and the car is stuck in 'P'. U0101: Lost Communication with TCM U0100: Invalid Data Recieved from ECM / Power control module A Where is best to start with this, shall i check all fuses and passenger footwell BCM or pull the wiring diagrams, I havnt got enough money to take it to an Auto-Electrician and want to resolve my self, please any advice would be useful. Quote Link to comment Share on other sites More sharing options...
Tony1yont Posted Sunday at 04:17 PM Share Posted Sunday at 04:17 PM Get yourself a basic multimeter from amazon and check fuses next to battery in the engine bay and beneath passenger footwell there is a few few fuses there as a starter mate Quote Link to comment Share on other sites More sharing options...
unofix Posted Sunday at 04:31 PM Share Posted Sunday at 04:31 PM 3 hours ago, Automaticsford said: cleared them all down and have a few low voltage ones and some U codes with loss communications and the car is stuck in 'P'. In almost all cases like this you just need to disconnect the negative battery terminal for at least 20 minutes. Then reconnect and wait for 5 minutes before turning the ignition on. Also you need to check that your new battery is fully charged. Did you reset the BMS after replacing the battery ? 1 Quote Link to comment Share on other sites More sharing options...
Automaticsford Posted Sunday at 04:45 PM Author Share Posted Sunday at 04:45 PM 13 minutes ago, unofix said: In almost all cases like this you just need to disconnect the negative battery terminal for at least 20 minutes. Then reconnect and wait for 5 minutes before turning the ignition on. Also you need to check that your new battery is fully charged. Did you reset the BMS after replacing the battery ? No, I can do that too, then depending on codes what do i strip next the terminals around the TCM, i think these are in the drivers headlight. Quote Link to comment Share on other sites More sharing options...
Automaticsford Posted Monday at 04:22 PM Author Share Posted Monday at 04:22 PM Hi - I have now, changed battery and reset the BMS , The car is on and the IPC is also on. Also when you disconnect the negative the car does actually start but then then doesn't come back on main fault is 'Transmission not in Park' even thought its in P and flashing it thinks its not as i believe there is no communication from the TCM. Below are the codes I am getting, mainly lost communication ones. Should I check the fuse for the TCM first and chase the wiring for the TCM? Does anyone have any useful wire diagrams or where is best place to start for this. ===PCM DTC P0722:00-27=== Code: P0722 - Output Shaft Speed Sensor Circuit No Signal ===PCM DTC U1013:87-27=== Code: U1013 - Invalid Internal Control Module Monitoring Data Received from TCM ===PCM DTC P0113:00-27=== Code: P0113 - Intake Air Temperature Sensor 1 Circuit High (Bank 1) ===PCM DTC U0101:00-27=== Code: U0101 - Lost Communication with TCM ===PCM DTC U101A:00-27=== Code: U101A - Lost Communication With TCM - Multiple Bus ===OBDII DTC U0101-P=== Code: U0101 - Lost Communication with TCM ===ABS DTC U0101:00-2F=== Code: U0101 - Lost Communication with TCM ===GSM DTC U0100:00-AF=== Code: U0100 - Lost Communication With ECM/PCM A ===GSM DTC U0301:00-AF=== Code: U0301 - Software Incompatibility with ECM/PCM ===GSM DTC U0100:87-AF=== Code: U0100 - Lost Communication With ECM/PCM A ===IPC DTC U0100:00-8A=== Code: U0100 - Lost Communication With ECM/PCM A ===IPC DTC U0146:00-0A=== Code: U0146 - Lost Communication With Serial Data Gateway 'A' Quote Link to comment Share on other sites More sharing options...
unofix Posted Monday at 04:35 PM Share Posted Monday at 04:35 PM Start at the TCM connector(s) on the gearbox. Unplug them and remove the plastic back Shell. Check for corroded and/or broken wires in the back of the connector. Quote Link to comment Share on other sites More sharing options...
Automaticsford Posted Monday at 04:44 PM Author Share Posted Monday at 04:44 PM great will do as it shows no response from TCM. 1 Quote Link to comment Share on other sites More sharing options...
Tony1yont Posted Monday at 07:11 PM Share Posted Monday at 07:11 PM Ok, I have check the connector to the TCM, and the tcm ... the pins look fine I've taken the plastic cover off and tested the pins and various pins/wires have 12 V. So really not sure where to go from here or I'm not testing it right. I've also plugged it into another TCM i have and still no communication. So conclusion, is there is no response for the TCM and no TCM on the tree. Where would I go from here. Quote Link to comment Share on other sites More sharing options...
Grisleigh Posted yesterday at 09:53 AM Share Posted yesterday at 09:53 AM Here is the info you requestedmk4 Focus data sheet DK68JZG.pdfCell 030 Page 06.pdfCell 030 Page 05.pdfCell 030 Page 01.pdfCell 024 Page 15.pdfCell 014 Page 02.pdfCell 013 Page 19.pdfCell 013 Page 03.pdfCell 010 Page 01.pdf 1 Quote Link to comment Share on other sites More sharing options...
Tony1yont Posted yesterday at 09:59 AM Share Posted yesterday at 09:59 AM Thank you Quote Link to comment Share on other sites More sharing options...
