PlepPlep Posted September 4 Share Posted September 4 Hi, radiator fan will not kick on when engine gets hot. I checked the relay and it is working as I did a test on it and it clicks. The radiator fan is working also as I put battery power to it and fans away. I do not know where to look next. What else should I be checking? Might it be the sensor? If yes...might it need replacing? I do not know where this is if anyone can help? Thank you 👍 Quote Link to comment Share on other sites More sharing options...
unofix Posted September 4 Share Posted September 4 2 minutes ago, PlepPlep said: Might it be the sensor? Possibly. If you disconnect the temperature sensor the fan should run all the time the ignition is on. 3 minutes ago, PlepPlep said: .might it need replacing? Yes if it is faulty. 3 minutes ago, PlepPlep said: I do not know where this is if anyone can help? Watch the video..... 1 Quote Link to comment Share on other sites More sharing options...
Paulkp Posted September 4 Share Posted September 4 Does it run with the aircon on ? Quote Link to comment Share on other sites More sharing options...
