Cas65 Posted June 30 Share Posted June 30 If i replace the car battery in my 2016 Mondeo 2.0 desiel estate do i need to do anything else other than installing the battery. Quote Link to comment Share on other sites More sharing options...
unofix Posted June 30 Share Posted June 30 You will need to reset the battery Monitor System (BMS). Not sure on your 2016 model if you need method 1 or method 2 On 3/29/2023 at 8:13 PM, unofix said: How to reset the BMS method 1 Search Tag: BMS1 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted June 30 Share Posted June 30 On 3/29/2023 at 8:14 PM, unofix said: How to reset the BMS method 2 Search Tag: BMS2 1 Quote Link to comment Share on other sites More sharing options...
Cas65 Posted July 2 Author Share Posted July 2 Cheers for that Quote Link to comment Share on other sites More sharing options...
Keven Posted July 21 Share Posted July 21 On 6/30/2024 at 9:10 PM, unofix said: You will need to reset the Battery Monitor System (BMS). Not sure on your 2016 model if you need method 1 or method 2 Thanks, that's done now and all seems to be working ok, really appreciate your help 2 Quote Link to comment Share on other sites More sharing options...
