Rdee Posted June 24 Share Posted June 24 I have a 2021 Focus 1.0 ecoboost MHEV with the digital display, ( 20,000 miles ) only just noticed when i put ignition on there is no oil pressure warning light, i have checked the manual and it gives little info, also i have found photos of this display online again with the ignition on but not running, battery light on and all warning lights showing but no oil pressure light displayed, do they have a warning light which comes on with the ignition or does it only illuminate when you have a problem when the engine is running? Quote Link to comment Share on other sites More sharing options...
unofix Posted June 24 Share Posted June 24 1 hour ago, Rdee said: I have a 2021 Focus 1.0 ecoboost MHEV That's not what your profile says you have 馃 The digital dashboard gives a warning message about low oil pressure telling you to "Stop" immediately. 1 Quote Link to comment Share on other sites More sharing options...
Rdee Posted Monday at 09:18 PM Author Share Posted Monday at 09:18 PM Car in to the Ford dealer to be checked, they have been on to Ford Technical who say that these do not have an oil warning light that comes on as a start up test, it only comes on if there is an oil pressure problem when the engine is running, they say it has something to do with the stop start or the digital display, apparently they checked a new car in the showroom and it was the same, they did however find an issue with the oil monitoring system wiring harness which will have to be replaced under warranty. 1 Quote Link to comment Share on other sites More sharing options...
