Skirkle Posted June 23 Share Posted June 23 Got a problem with a locking wheel nut where the outer ring has came off and the key feels like it has nothing to grip on to. Any suggestions on how I could remove it myself? Cheers! Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 23 Share Posted June 23 The key should have an equivalent 'flower' pattern to fit it. You can pack some cardboard around the edge if it's slipping off now. The outer ring is just for security, to stop thieves hammering an oversized socket onto it. As it's come off, you could try just hammering an oversized socket over it. Or if there is some grip to the socket, put some gentle sideways pressure on it, then tap the back of the bar with a hammer to shock it loose without slipping off. (Only works with a bar, don't hammer a ratchet) 1 Quote Link to comment Share on other sites More sharing options...
Danny cj Posted June 23 Share Posted June 23 As tomsfocus said..a 16mm socket and hammer it in..then a breaker bar or wrench with a longer handle..maybe a jack handle pipe..it may ruin the socket but it will come off Quote Link to comment Share on other sites More sharing options...
StephenFord Posted June 23 Share Posted June 23 Pretty sure that's a McGard wheel locking nut. If you have the key number (engraved on the key), you can easily buy a replacement... https://mcgard.de/en/ 2 Quote Link to comment Share on other sites More sharing options...
Alien1955 Posted Monday at 12:43 PM Share Posted Monday at 12:43 PM I had a similar problem, purchased some of these, worked brilliantly, make sure you have a new stud ready to go back in. Aussel 5PCS Twist Socket Set, Nut Extractor Socket, Locking Wheel Nut Extractor Remover Tool Set, 17mm 19mm 21mm 22mm Socket : Amazon.co.uk: DIY & Tools Quote Link to comment Share on other sites More sharing options...
unofix Posted Monday at 02:55 PM Share Posted Monday at 02:55 PM Don't you just love threads like this that rumble on and on, yet the original poster has never been back once to read any of the replies 🤣 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted Monday at 03:57 PM Share Posted Monday at 03:57 PM 1 hour ago, unofix said: Don't you just love threads like this that rumble on and on, yet the original poster has never been back once to read any of the replies 🤣 mmm... now if a tree falls in a forest with no witness, does it still make a sound?? 😁 Quote Link to comment Share on other sites More sharing options...
