Dan_B1990 Posted April 22 Share Posted April 22 Hello All, First post here so hoping I'm in the right spot/Forum! I've recently experienced the P20E9, P246B and P2462 codes which in turn have illuminated the engine management light. Previously the P20E9 "Diesel intake Air Flow Position Sensor Circuit High" wasn't logged and having seen the P246B and P2462 codes before when the fuel vaporiser was blocked I swapped it again for a new one and checked the 5A fuse which was fine but this hasn't solved the issue. Wondering if anyone has seen the P20E9 DTC before and if so how did they fix it? I've done some research and seen the sensor is part of the throttle body which are prone to failure, and when turning off the vehicle you can hear the throttle body still energised for a good time after. Does the P20E9 DTC also cause the reason for the regen conditions not being met? I've ordered a new throttle body in preparation but wanted to see if anyone else had seen this problem. P20E9 - Diesel intake Air Flow Position Sensor Circuit High P246B - Vehicle conditions incorrect for Diesel particulate filter regeneration P2462 - Diesel Particulate Filter - Soot Accumulation Thanks in advance, Dan B. Quote Link to comment Share on other sites More sharing options...
M-sport2279 Posted 2 hours ago Share Posted 2 hours ago Hey Dan_B1990 Just curious to know if you ever resolved this issue? I have a similar issue with my S-max. Cheers Mat Quote Link to comment Share on other sites More sharing options...
