Mizsga Posted January 24 Share Posted January 24 Hello! I am contacting you because I feel that the mechanic is asking for an irrelevant amount for the complete renovation of the Bosch CR injector. He claims all 4 are bad. The car was running fine. Sometimes only 3 cylinders went, that's why I took it to the service center. I doubt that all 4 injectors are bad. Approximately how much would it cost to renew the injectors per piece? Ford Fiesta 2009 1.6 TDCI 55kW HHJF Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 24 Share Posted January 24 Rough prices: Brand new injector - £200 each Reconditioned injector - £100 each Reconditioning of your existing injector - £100 each Quote Link to comment Share on other sites More sharing options...
Mizsga Posted January 24 Author Share Posted January 24 The mechanic would charge 155 gbp for 1 piece. Quote Link to comment Share on other sites More sharing options...
Mizsga Posted January 24 Author Share Posted January 24 It also says that all 4 injectors are bad. But the car started perfectly, it had so many problems that the idle speed jumped when starting. However, when the rpm was higher, the car worked perfectly. I doubt that all 4 injectors are bad. What do you think? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 24 Share Posted January 24 After 1 injector fails at this age, others often fail soon after. You can choose to start with 1 and see how it goes though. You don't say whether that price is brand new or reconditioned. Or whether it includes removal and refitting. Quote Link to comment Share on other sites More sharing options...
Mizsga Posted January 24 Author Share Posted January 24 It's just a bad injector overhaul. without unpacking and putting back. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 25 Share Posted January 25 14 hours ago, Mizsga said: It's just a bad injector overhaul. without unpacking and putting back. Ok, that does sound a bit expensive then. It's probably cheaper to buy a refurbished injector instead. Or if you do want to have yours refurbished, maybe contact Diesel Bob to see what price he would charge for that. Diesel Bob (UK) Ltd - Injectors 1 Quote Link to comment Share on other sites More sharing options...
nicam49 Posted January 25 Share Posted January 25 Don't forget the 20% vat on top of the prices... 🤔 Maybe your injectors cost more to overhaul due to the cost of replacement parts. Quote Link to comment Share on other sites More sharing options...
