macaulays Posted January 4 Share Posted January 4 Afternoon All, I have been having intermittent issues recently with a warning flashup just after setting off re ESC, park assist etc being disabled which disappears after a few minutes. Nothing flagged with a generic OBD reader I had but have tried Forscan for the first time today which has, among a couple of others, a code in the ABS module flagging "Circuit Short to battery or Open" for the Right Front Wheel Speed Sensor. I have seen a few other references outwith the Galaxy forum to this on Mondeos etc as a not uncommon issue to crop up. Is there any way of knowing from that code whether the remedy is likely to be replacing the ring or the actual sensor? Or would that need physical inspection to confirm typically? Many thanks for any thoughts. Sandy Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 4 Share Posted January 4 That fault code suggests there isn't any 'return' voltage from the sensor. So likely to be the sensor itself or the wiring between sensor plug and ABS module plug. That would need to be visually inspected, and if no obvious damage, wiring tested with a multimeter. Quote Link to comment Share on other sites More sharing options...
unofix Posted January 4 Share Posted January 4 2 hours ago, macaulays said: Right Front Wheel Speed Sensor. Original factory part as far as I know was Finis Code 1877755. This part may now have been superseded by Finis Code 2504175. Cost of the part is just under £90 and will take less than an hour to fit. Quote Link to comment Share on other sites More sharing options...
macaulays Posted January 5 Author Share Posted January 5 Excellent, thanks both - I will see if I can track down that sensor in that case. Assistance most appreciated! All the best, Sandy 1 Quote Link to comment Share on other sites More sharing options...
