pinball wizard Posted August 29, 2023 Share Posted August 29, 2023 Hi folks, first time poster so grateful for any help in this one... I have a 14 plate MK3 Focus Titanium Nav. About four days ago whilst driving I had an on screen notification that a rear light was faulty. Upon inspection I've found it is the drivers side brake light. All other lights are working fine on drivers side and passenger side, it's just the drivers side brake light which is intermittently working. Knowing that the other brake lights are working fine I'm for now ruling out any switch/fuse issue.. I've replaced the bulb on the offending lamp and its still intermittently not working. I've cleaned the contacts on the bulb connector and all looks fine. Any ideas as to what could be causing this issue and what I could try next to resolve without an expensive trip to a garage? Thanks Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted August 29, 2023 Share Posted August 29, 2023 Check you're getting full connection Quote Link to comment Share on other sites More sharing options...
pinball wizard Posted August 29, 2023 Author Share Posted August 29, 2023 3 hours ago, DaveT70 said: Check you're getting full connection Hi, thanks for replying. Do you mean check the connection between the bulb and the bulb fitting? Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted August 29, 2023 Share Posted August 29, 2023 5 minutes ago, pinball wizard said: Hi, thanks for replying. Do you mean check the connection between the bulb and the bulb fitting? Yes and the fitting to the harness 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted August 29, 2023 Share Posted August 29, 2023 On 4/15/2023 at 10:17 PM, unofix said: The ground tab in the lamp holder is not protruding far enough out and is not making contact with the side of the bulb. It just needs eased out a few millimeters with a small screwdriver. 2 1 Quote Link to comment Share on other sites More sharing options...
pinball wizard Posted August 29, 2023 Author Share Posted August 29, 2023 Thanks guys, seems to have done the trick. So far so good. Will see how it goes tomorrow and report back. Thanks again Quote Link to comment Share on other sites More sharing options...
pinball wizard Posted August 30, 2023 Author Share Posted August 30, 2023 All good today 👍🏻 1 Quote Link to comment Share on other sites More sharing options...
