StokesBoys1234 Posted February 8, 2023 Posted February 8, 2023 Hi there, is there anyone that could help with a guide on how to change just the oil cooler on my 2009 1.6tdci. The oil cooler started leaking coolant this evening as it looks as though the dpf heat shield has become loose and has been rubbing on the oil cooler creating a hole. Do I need to remove the turbo and dpf to get to the cooler, or is it accessible without removal? I’ve sourced the cooler on euro car parts so I’m hoping it can be changed on its own without the replacement of the complete oil filter housing 😬. If anyone has a guide or have shared a similar experience I’d appreciate some guidance 🙂
TomsFocus Posted February 9, 2023 Posted February 9, 2023 Hi, this is one of very few jobs on the 1.6 TDCI that I haven't done unfortunately. Given the lack of replies to your previous thread, I'd suggest none of the other regulars on here have done it either. I don't think the DPF will be in the way, although you might need the right tools to reach the bolts on that side. (Extensions/UJ's may help). The turbo definitely doesn't need removing. My main concern would be getting the new one totally sealed. Does it come with a new gasket? If not, I'd recommend buying one, or using some liquid gasket if reusing the original.
Tim Roberts Posted 5 hours ago Posted 5 hours ago On 2/8/2023 at 10:38 PM, StokesBoys1234 said: Hi there, is there anyone that could help with a guide on how to change just the oil cooler on my 2009 1.6tdci. The oil cooler started leaking coolant this evening as it looks as though the dpf heat shield has become loose and has been rubbing on the oil cooler creating a hole. Do I need to remove the turbo and dpf to get to the cooler, or is it accessible without removal? I’ve sourced the cooler on euro car parts so I’m hoping it can be changed on its own without the replacement of the complete oil filter housing 😬. If anyone has a guide or have shared a similar experience I’d appreciate some guidance 🙂 I have the same problem. Did you manage to get it sorted and if you did, did you manage to do it without removing the dpf? Thanks Tim
unofix Posted 5 hours ago Posted 5 hours ago 24 minutes ago, Tim Roberts said: Did you manage to get it sorted and Don't think you will get an answer.
Tim Roberts Posted 5 hours ago Posted 5 hours ago 6 minutes ago, unofix said: Don't think you will get an answer. 😂😂 Can you help me??
unofix Posted 4 hours ago Posted 4 hours ago 16 minutes ago, Tim Roberts said: Can you help me?? Sorry I don't know. The person who would normally be able to answer this would be @TomsFocus BUT, as he has already said above he also doesn't know 🙄 1
Register a new accountSign in
