Ray Puma Posted October 28, 2022 Share Posted October 28, 2022 I bought a new Ford Puma St Line from the local Ford Dealership in August last year. In August this year the FordPass App reported to my phone that the car had gone into Deep Sleep mode and "Remote features disabled to preserve battery and Don't worry though, nothing is wrong" and the solution was to simply restart the vehicle. However, the this problem has continued. Sometimes it appears to go into a deeper sleep mode and air-conditioning is disabled and I think the Auto Start/Stop behave differently. The car generally sends the message whenever the engine is turned off though sometimes when it is stared and occasionally at random intervals such as 4:00 PM The car has now been back to the dealer for investigation on three occasions for a total of seven days/nights and it is due to go back again in a couple of weeks. The dealer has been unable to identify the problem. Ford Motors say that the there are only three triggers for the messages 1) High temperature 2) car not driven within 14 days 3) battery voltage below 9.4 volts. Full details of the fault notifications are retained on the Ford servers but they decline to send me a copy of what precisely has trigger the notifications I am receiving and the dealership appears unable to get any information from Ford. Has anyone experienced a similar problem and has it been resolved? If so what was the solution? Ray 1 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted October 28, 2022 Share Posted October 28, 2022 How often and how far do you normally drive? Has the dealer fully charged the battery? Have they checked for a TCU update? Quote Link to comment Share on other sites More sharing options...
Andyr55 Posted October 29, 2022 Share Posted October 29, 2022 I have the same problem as a low mileage user. I put mine on charge every couple of weeks if I haven’t used the car. maypole charger recommend from this site. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted October 29, 2022 Share Posted October 29, 2022 2 hours ago, Andyr55 said: maypole charger recommend from @StephenFord ............ 🤣🤣 1 Quote Link to comment Share on other sites More sharing options...
PolarMonk63 Posted June 9, 2023 Share Posted June 9, 2023 Hi fellow Puma owners, I had exactly the same problem with mine (18 months old now).The app constantly reporting deep sleep AND the aircon not working when the message appeared. I didn’t notice at first, because it started in winter time so I don’t use the aircon then. Went to my dealer who didn’t have a clue! Assuming I wasn’t the only one having this problem, I searched the internet with my best friend Google. There I found a BMS (battery management system) reset procedure. Don’t think I’m fooling you when reading the instructions below, it’s not a joke! Unlock your car and activate it with the start button. Don’t start it so foot off the break pedal. Activate the head lights manually Flash your high beam 5 times Press the break pedal 3 times De-activate the car. The BMS is now reset and the deep sleep doesn’t occur anymore. Also the aircon is working properly. Worked like a charm for my Puma, hope I could help you with the same issue! Arno Klomp, The Netherlands. 1 1 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted June 9, 2023 Share Posted June 9, 2023 Don’t reset the BMS unless you are fitting a new battery! 1 Quote Link to comment Share on other sites More sharing options...
PolarMonk63 Posted June 9, 2023 Share Posted June 9, 2023 Is an 18 month old battery supposed to be gone already? Are you sure the BMS software doesn’t contain bugs? My Puma works flawlessly after this. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted June 9, 2023 Share Posted June 9, 2023 2 hours ago, PolarMonk63 said: Are you sure the BMS software doesn’t contain bugs? Very sure it doesn't. It's not much more than a current data logger that passes the info to the BCM. Have you measured the battery terminal voltage with a digital multimeter, approximately 1 hour after parking the car ? Quote Link to comment Share on other sites More sharing options...
alexp999 Posted June 9, 2023 Share Posted June 9, 2023 Disconnecting the negative terminal and leaving it for 10 mins is enough to force a SoC recalibration the next time it’s locked and left overnight. Resetting the BMS with pedal sequence or Forscan resets the battery age to zero. Quote Link to comment Share on other sites More sharing options...
Andrew Barker Posted December 11, 2023 Share Posted December 11, 2023 Hi all PUMA ST 2021 kept going deep sleep mode and battery failed even though used regularly for decent journeys Ford dealer saying TCU unit is slowly draining it New one being fitted will repost after this done to let you know if battery stays charged Quote Link to comment Share on other sites More sharing options...
F0CUE Posted December 11, 2023 Share Posted December 11, 2023 5 Quote Link to comment Share on other sites More sharing options...
Ludovic34 Posted May 12 Share Posted May 12 Hi everyone! I'm a french puma's owner and I've got the same problem with my vehicle... Deep sleep mode, impossible to open the doors with key and starting it. In the ford dealer since one month and no issue find. Have you finally find the issue to solve this problem? Thanks Quote Link to comment Share on other sites More sharing options...
unofix Posted May 12 Share Posted May 12 You are posting in the wrong forum (it's not your fault). Post your question in the PUMA forum https://www.fordownersclub.com/forums/forum/35-ford-puma-club/ Quote Link to comment Share on other sites More sharing options...
DebsC Posted October 11 Share Posted October 11 Hi, I brought my ford puma last October, Ive had no problems up and till today. Went to go out and the car was completely dead. No power what's so ever, couldn't press down on the brake and the start button did nothing. My puma is automatic. My friend has put the battery on slow charge overnight, as it was the only thing that made any sense to do. I did receive a message from my app stating it had gone into a deep sleep, even though I had been out in the car earlier that day. Has this been an issue for anyone else? Quote Link to comment Share on other sites More sharing options...
unofix Posted October 11 Share Posted October 11 17 minutes ago, DebsC said: Has this been an issue for anyone else? Have you read this thread ? Quote Link to comment Share on other sites More sharing options...
