Warwick Posted September 18, 2022 Share Posted September 18, 2022 I'm having issues with vibration associated with the engine on my Focus Zetec 1.8 Estate. It is largely noticeable on tick over. Please can anyone inform me how many engine mountings are fitted on this car. I know that there is one at each side of the engine. There is one located below the area of the cooling water reservoir. the other is located at the opposite side of the engine below the battery / air filter. I'm unsure if there is another located at the rear of the engine / gearbox. I think that there is on some models (Perhaps the 2 litre model). I have already replaced the mount below the water reservoir. This has slightly improved the level of vibration, but not cured it. I now intend to replace the mount below the battery / air filter. If there is an additional mount, I'd be most grateful if someone can verify that. Many thanks Quote Link to comment Share on other sites More sharing options...
rd457 Posted September 18, 2022 Share Posted September 18, 2022 5 hours ago, Warwick said: If there is an additional mount, I'd be most grateful if someone can verify that. Indeed there is; according to my copy of the Haynes manual (2005-2011 petrol edition) such a third ("roll restrictor") mount exists on 1.4, 1.6, 1.8 and 2.0 litre models. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted September 19, 2022 Share Posted September 19, 2022 There is a lower mount on all engines, but it doesn't do much for vibration. It's main purpose is to stop the engine swinging back & forth under acceleration and braking. Very easy to change as you don't need to support the engine for that one. 1 Quote Link to comment Share on other sites More sharing options...
