Windscreen wipers not working
Connor94
 Share
Hi all, looking for a bit of advice.
My wind screen wipers are not working at all. Washer pump is working and all fuses have been tested ok. I have replaced the motor and the switch still to no avail. Next thing to check is the BCM before I go ahead and do this is there anything I should check? Can anyone provide a wiring diagram?
Cheers in advance,
Connor
Link to comment
My goodness that's a lot of work !!
I would recommend downloading FORScan (it's free for use on a laptop) and buy the new 'vLinker FS' connecting cable. Then you most probably will be able to diagnose the fault quickly and without the need to guess which is expensive and time consuming.
FORScan: https://forscan.org/download.html
vLinker FS connection lead : https://www.obd2shop.co.uk/wholesale/vgate-vlinker-fs-elm327-for-ford.html?gclid=CjwKCAjwpKyYBhB7EiwAU2Hn2ckEMPZgWytToAd3yCV3qQFVSzH_JvjJGXAtiGa3dWRbnXfK1qHDaBoC4J0QAvD_BwE
Link to comment
I know it’s easy to say this:  before you replaced the motor did you check if there was 12 volts on the wire to it?  Presumably there wasn’t 12 volts on the relevant wire and therefore replacing the motor wasn’t going to fix it.  On my brothers 2008 focus the wipers stopped working. The fault was within the bcm. In the end I rewired supply to motor with a toggle switch next to the heated rear window switch so the bcm had no involvement in the wipers. Not ideal but it was certainly easier and cheaper than fixing it properly. My fix would not be to everyone’s taste I admit.  But at least it meant the car was usable and mot passable
Link to comment
Thanks unofix, I have now run the diagnostics and been given the following error code from the bcm “B1C53 - Front wiper Intermittent data
Additional fault symptom: Open Circuit”
Any idea what the next move is?
thanks in advance
Connor
  • Like 1
Link to comment
Here @Connor94 is a link to my private Google drive with the fiesta wiring schematics
On 8/31/2022 at 8:03 PM, unofix said:
Wiring schematics for Fiesta
Mk7 - 2012 onwards
2017 - 2020
2020 - 2021
https://drive.google.com/file/d/1TZZeRYoX_6lTXN_tS6ZfEuN2dHhdt6SR/view?usp=sharing, https://drive.google.com/file/d/1ghvIf0WBn6SYTqdf2biBR9qs3kPwb4Zs/view?usp=sharing, https://drive.google.com/file/d/1qalYB5510zbnJfwtpTsbyYiFK2U3HUgB/view?usp=sharing
I will leave these available until 8th Sept 2022 for anyone who may have a need of them.
Link to comment
As you will see from the schematics the wiper motor is controlled from the BCM.
First I would disconnect the negative lead from the car battery.
Then remove all plugs from the BCM and even remove the BCM from the car. Inspect all connectors and pins for any signs of corrosion and/or water ingress.
Check the circuit board of the BCM for signs of greenish corrosion. If every thing looks OK then use a multimeter and start checking the wiring from the wiper switch to the connector of the BCM. Look for either high resistance or open-circuit in the wiring.
Link to comment
Hi Unofix, okay so i have got a new BCM and the wipers are now working. I have taken a back up of the configuration of my old BCM and when i go to load it to the new one it says there is a "configuration structure mismatch". Does this mean i have ordered the wrong bcm replacement? My old one had 13 hex blocks and the new one as a lot more?
Cheers,
Connor
Link to comment
That sounds like you have the BCM for a higher spec model. What is the full part number of both the old and new BCM
Link to comment
Old BCM DN1T-15K600-CE
New BCM AV1T-15K600-GH
Apologies i'm pretty new to all this - take it I need a like for like replacement?
Cheers,
Connor
Link to comment
Is there anything that is not working?  If it’s all working properly what’s the worry?
Link to comment
Hi isetta, yeah central locking not working now. I'll need to properly test everything out first but FORscan shows that the BCM is not compatible.
Cheers,
Connor
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
  • Insurance
  • Support
