Erkiwi Posted August 17, 2022 Share Posted August 17, 2022 Hi I have a 2013 ford Mondeo 2 litre diesel , one morning started it up and an error transmission limited function appeared and the car went into limp mode.Turned engine off and restarted and everything is going great , had scan done and no error log came up. It has 77,000 Km on the clock and a full service on gearbox was done at 66,000 km. I has happened twice in a month each time a restart fixes the problem,any ideas what might be causing this issue? Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted August 17, 2022 Share Posted August 17, 2022 Check all your earth points are clean and good If it hasn't had a new battery for a while then I would suspect the battery is going down Quote Link to comment Share on other sites More sharing options...
nicam49 Posted August 17, 2022 Share Posted August 17, 2022 Did the Ford dealer do the scan or was it a generic code reader? I ask 'cos the generic ones won't pick up Ford-specific codes. Quote Link to comment Share on other sites More sharing options...
