Maximus59 Posted August 4, 2022 Share Posted August 4, 2022 I have a 2017 Ford Focus and after putting new brake pads on and driving between 20/30 miles they have started squealing, looking for remedies to the problem do I need to apply copper past if yes what area of the pads do I apply the past ? On all 4 pads ? Quote Link to comment Share on other sites More sharing options...
isetta Posted August 4, 2022 Share Posted August 4, 2022 I have always put copper grease on every area of the metal backing where it touches anything else, that’s on the back of the pads and the edges of the metal backing. Sparingly though. Quote Link to comment Share on other sites More sharing options...
Maximus59 Posted August 5, 2022 Author Share Posted August 5, 2022 That’s very kind of you to answer do you mean that you copper grease the metal clips that go into the piston caliper ? As well as the surrounding metal areas? Quote Link to comment Share on other sites More sharing options...
RMurphy195 Posted August 5, 2022 Share Posted August 5, 2022 As Issetta says. DO NOT get the grease on the linings! If theres a shim between the back of the pad and the piston, just smear a thin film of grease over both sides of the shim. Make sure all surfaces a clean and dust-free first of course. Quote Link to comment Share on other sites More sharing options...
Maximus59 Posted August 5, 2022 Author Share Posted August 5, 2022 Hi yes I understand that you wouldn’t put grease on the linings only the rear metal parts of the pads my question is what about the metal clips that go into the piston caliper? Thanks for answering 👍 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted August 6, 2022 Share Posted August 6, 2022 23 hours ago, Maximus59 said: Hi yes I understand that you wouldn’t put grease on the linings only the rear metal parts of the pads my question is what about the metal clips that go into the piston caliper? Thanks for answering 👍 No they don't need greased. Also a good idea to pull out the pistons and grease them with some red rubber grease so they don't stick. Quote Link to comment Share on other sites More sharing options...
Maximus59 Posted August 6, 2022 Author Share Posted August 6, 2022 Thanks that’s great advice, will let everyone know how I get on 🤞🤙 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted August 7, 2022 Share Posted August 7, 2022 What brand and type of brake pads did you use? Brake pads should have a chamfered edge to prevent squealing. When installing brake pads that do not come with a chamfered edge you should apply the chamfered edge yourself (for example by sanding/grinding). Copper grease is a thing from the past. I have not seen copper grease been prescribed for brakes in workshop manuals within the last 20 Years. There are much better products recommended/prescribed by brake manufacturers for this purpose. Most dedicated brake lubricants are ceramic or silicone based. I always use the Brembo B-Quiet for brake pads. It is pretty inexpensive and will serve you many Years. When the brake pads do still squeal after you made sure that the pads have a chamfered edges and are properly lubricated there is not much you can do. Some brake pads that are made from hard friction material have the nasty ability to squeal. For example Bosch brake pads and Motorcraft brake pads (also made by Bosch) are well known for squealing. 2 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted August 7, 2022 Share Posted August 7, 2022 This is also very good and lasts a very long time. https://www.ebay.co.uk/itm/254103769943?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=isQBGrctTv-&sssrc=2349624&ssuid=7Sl-KwUsRoG&var=&widget_ver=artemis&media=COPY Quote Link to comment Share on other sites More sharing options...
mjt Posted August 7, 2022 Share Posted August 7, 2022 That's what I used last time and have had no problems with squeal. 1 Quote Link to comment Share on other sites More sharing options...
Maximus59 Posted August 10, 2022 Author Share Posted August 10, 2022 Ok guys I have ordered the MINTEX CeraTec Ceramic Brake Grease Anti Squeal as recommended should be arriving next Tuesday so will let you all know how it’s working out cross fingers it works thanks again for all the good advice Quote Link to comment Share on other sites More sharing options...
Maximus59 Posted August 11, 2022 Author Share Posted August 11, 2022 Some one asked what pads I have they are Brembo front pads thanks Quote Link to comment Share on other sites More sharing options...
Maximus59 Posted August 17, 2022 Author Share Posted August 17, 2022 Hello well I have fitted my Brembo front pads , I have used the mintex cera tec ceramic brake grease anti squeal as recommended and I have applied in all the recommended areas and I have done 30 miles and I still have some brake squealing? So I am at a loss as to what to do next? any suggestions? thanks Quote Link to comment Share on other sites More sharing options...
andypsp Posted August 17, 2022 Share Posted August 17, 2022 try another make in the pads, Brembo are not all there cracked up to be., i`ve never had problems with mintex or pagid brands Quote Link to comment Share on other sites More sharing options...
Maximus59 Posted August 18, 2022 Author Share Posted August 18, 2022 Thanks Andy I had a feeling that might be the case or just put up with the squealing 😞 Quote Link to comment Share on other sites More sharing options...
Maximus59 Posted September 21, 2022 Author Share Posted September 21, 2022 well I have done 300 miles on these Brembo pads, squealing starts used copper past no change used mintex past still no better loud squealing so I have given up and I have fitted new Ford front pads and I have done 100 miles with no paste and no squealing result. So I guess always fit Ford replacement parts Quote Link to comment Share on other sites More sharing options...
alanfp Posted September 21, 2022 Share Posted September 21, 2022 13 minutes ago, Maximus59 said: well I have done 300 miles on these Brembo pads, squealing starts used copper past no change used mintex past still no better loud squealing so I have given up and I have fitted new Ford front pads and I have done 100 miles with no paste and no squealing result. So I guess always fit Ford replacement parts Sometimes that's absolutely right... though not always. But you only find out which parts should be Ford and which can be non-Ford, by experience or getting advice from a forum like this. 1 Quote Link to comment Share on other sites More sharing options...
VFR800 Posted September 24, 2022 Share Posted September 24, 2022 Did you break them in correctly? Try a few high speed, high brake force runs to get some heat into them and see if that helps. I've come across instances where people have been really light on the brakes and the pads have glazed, either that or you may have a master cylinder issue and reduced brake force being applied. Quote Link to comment Share on other sites More sharing options...
TECHY7 Posted October 13, 2023 Share Posted October 13, 2023 On 8/4/2022 at 6:43 PM, Maximus59 said: I have a 2017 Ford Focus and after putting new brake pads on and driving between 20/30 miles they have started squealing, looking for remedies to the problem do I need to apply copper past if yes what area of the pads do I apply the past ? On all 4 pads ? Hi Maximus59, I know this is an old post but it is a subject that never seems to completely go away. I am chasing just such a problem now. When you say you used Ford pads were they actually Ford pads or were they Motorcraft pads. I know they are supposed to be just the same but I would be interested to know, and have they continued to behave. Regards, Ken Quote Link to comment Share on other sites More sharing options...
