newbie and sidelights problem
ashes-uk
 Share
Im going insane....
So got hold of a low miles mk2 08 auto.
Issue with sidelights - no power to bulb socket.
Fuses fine (replaced and tested), bulbs fine (replaced and tested), re-seated fuse connectors in footwell, cleaned all connectors
rear lights working ok
Power going to main lighting socket, pin 4 & 6, no power coming out to bulb side on both.
Am I looking at removing the lens as I cant get to the rear of the bladed connectors on the light unit?
So frustrating. Or am I missing a "trick"
Bar that loving the wind noise on drivers window (!)
Link to comment
My drivers window is silent. If you press against it when hearing the noise, does it stop?
Link to comment
Maybe a bad connection in one of the plugs on the bcm under the glovebox.  The electrical thing under the glovebox looks like a fuse box but is much more, it has computer chips in it and controls everything. It has a huge number of wires in plugs on it.  Sometimes these show signs of corrosion on the pins.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
  • Insurance
  • Support
