Colin McDonald Posted January 15, 2020 Share Posted January 15, 2020 Hi there. I have a 66 plate S-Max and every now and then I get the following warnings on the dash: ESC service Required Check Park Pilot Hill start assist not available the warning lights ABS and traction control (car skidding and car skidding with OFF underneath) there does not seem to be any difference in driving and after a few seconds all the warnings disappear the car has just had a service and nothing has been highlighted any ideas? Quote Link to comment Share on other sites More sharing options...
Meta55 Posted February 11, 2020 Share Posted February 11, 2020 I have a late 2015 and mine is doing the same. I’m hoping my friend will bring his snap on code reader home very soon, to check for codes. Has your car been in for the battery terminal recall. Mines has done it ever since then. Quote Link to comment Share on other sites More sharing options...
Meta55 Posted February 14, 2020 Share Posted February 14, 2020 Car was put on the scanner tool tonight. Fault showing as front r/h speed sensor. Mechanic reckons that it’s a corroded cable, giving the fact the fault is intermittent. Will try and have a look over the weekend. Quote Link to comment Share on other sites More sharing options...
Alvintc Posted June 28, 2020 Share Posted June 28, 2020 Ever get an answer for this? I have the exact same issue on my 66 plate s-max. I can manually trip it by putting full left lock on so I'm guessing it's a sensor on the front wheel arches... Quote Link to comment Share on other sites More sharing options...
brains_t Posted June 29, 2020 Share Posted June 29, 2020 Quote Link to comment Share on other sites More sharing options...
Meta55 Posted June 29, 2020 Share Posted June 29, 2020 I removed the drivers side front sensor and gave it a clean, as this was the one showing the fault on the scanner. Never had the fault show up since then, that’s been 3 months now. Quote Link to comment Share on other sites More sharing options...
Kelly W Posted August 19, 2020 Share Posted August 19, 2020 I am having the same issue, mine is a 66 plate smax, I had my break pads done during covid not from main dealer just someone local who was open, and it started around 3 weeks after then. It’s doing my head in coming on loads through journeys, feels like the car looses slight power sometimes too! Did anyone get a solution to it? Quote Link to comment Share on other sites More sharing options...
Meta55 Posted August 19, 2020 Share Posted August 19, 2020 4 hours ago, Kelly W said: I am having the same issue, mine is a 66 plate smax, I had my break pads done during covid not from main dealer just someone local who was open, and it started around 3 weeks after then. It’s doing my head in coming on loads through journeys, feels like the car looses slight power sometimes too! Did anyone get a solution to it? Drivers side abs sensor. I’ve found out since mine first did it, that’s it’s a very common problem. Get a code read to confirm which sensor for sure. Quote Link to comment Share on other sites More sharing options...
smax driver Posted August 20, 2020 Share Posted August 20, 2020 On 1/15/2020 at 3:43 PM, Colin McDonald said: Hi there. I have a 66 plate S-Max and every now and then I get the following warnings on the dash: ESC Service Required Check Park Pilot Hill start assist not available the warning lights ABS and traction control (car skidding and car skidding with OFF underneath) there does not seem to be any difference in driving and after a few seconds all the warnings disappear the car has just had a service and nothing has been highlighted any ideas? I have this exactly. 66 plate smax. Did you get it sorted?? Quote Link to comment Share on other sites More sharing options...
smax driver Posted August 20, 2020 Share Posted August 20, 2020 23 hours ago, Kelly W said: I am having the same issue, mine is a 66 plate smax, I had my break pads done during covid not from main dealer just someone local who was open, and it started around 3 weeks after then. It’s doing my head in coming on loads through journeys, feels like the car looses slight power sometimes too! Did anyone get a solution to it? I also had break pads done! Quote Link to comment Share on other sites More sharing options...
smax driver Posted August 20, 2020 Share Posted August 20, 2020 On 6/29/2020 at 8:24 PM, Meta55 said: I removed the drivers side front sensor and gave it a clean, as this was the one showing the fault on the scanner. Never had the fault show up since then, that’s been 3 months now. Is this simple to do? or should a professional do it? My car is actually in for a service now and so far they don't know what the issue is after initial diagnostic so I can tell them!!! Do you know what may have caused it initially? thanks Quote Link to comment Share on other sites More sharing options...
Meta55 Posted August 23, 2020 Share Posted August 23, 2020 On 8/20/2020 at 5:58 PM, smax driver said: Is this simple to do? or should a professional do it? My car is actually in for a service now and so far they don't know what the issue is after initial diagnostic so I can tell them!!! Do you know what may have caused it initially? thanks Hi. The sensor is just held in by an 8-10mm bolt. Once it’s out, you just wiggle the sensor out then unplug. Try taking it out, give it a clean and put back in, see if that gives you a bit of time. Any research that I done, it always came back to the rh front this also included galaxy and Mondeo, and that was the one that through a fault on mine. Until you get a clear code on what the fault is, I would stick with cleaning it for now and check inside the cavity it sits in for any debris. Quote Link to comment Share on other sites More sharing options...
kmoore04uk Posted August 27, 2020 Share Posted August 27, 2020 Hi my Kuga and the Focus have just had a service and both cars are showing oil change required. Could someone please tell me how to clear the codes. Quote Link to comment Share on other sites More sharing options...
Meta55 Posted August 29, 2020 Share Posted August 29, 2020 On 8/27/2020 at 9:55 AM, kmoore04uk said: Hi my Kuga and the Focus have just had a service and both cars are showing oil change required. Could someone please tell me how to clear the codes. Think you have posted in wrong section. You need to be in the general ford section. Quote Link to comment Share on other sites More sharing options...
Sheen2326 Posted August 30, 2020 Share Posted August 30, 2020 On 6/29/2020 at 8:24 PM, Meta55 said: I removed the drivers side front sensor and gave it a clean, as this was the one showing the fault on the scanner. Never had the fault show up since then, that’s been 3 months now. Hi, can you tell me how easy it is to get to the sensor and where it is exactly? Thanks Quote Link to comment Share on other sites More sharing options...
Meta55 Posted September 5, 2020 Share Posted September 5, 2020 On 8/30/2020 at 1:21 PM, Sheen2326 said: Hi, can you tell me how easy it is to get to the sensor and where it is exactly? Thanks Hi. I sits on the hub above where the drive shaft goes in. It’s held in with an 8 or 10mm bolt. Once you have the bolt out, the sensor will pull out. You might have to gently prize under the base to get it started. Quote Link to comment Share on other sites More sharing options...
Maher Posted January 5, 2021 Share Posted January 5, 2021 I had the same issue. But my problem started when my car parked for a long time during the COVID lockdown. Then the steering started to be tough and difficult to manipulate finely. The company couldn’t get the problem. 6 months later I got this message with warning lights for electronic slide control or traction control and it says service required. Then driving for few seconds all went off. To my surprise, the steering problems which annoyed me for six months got rectified and steering problem disappeared. I called the agency and they asked me to visit them for a computer check. In fact I won’t go. They ignored my issue from the start and I’m afraid the steering wheel gets the same problem again Quote Link to comment Share on other sites More sharing options...
Meta55 Posted January 9, 2021 Share Posted January 9, 2021 On 1/5/2021 at 2:16 PM, Maher said: I had the same issue. But my problem started when my car parked for a long time during the COVID lockdown. Then the steering started to be tough and difficult to manipulate finely. The company couldn’t get the problem. 6 months later I got this message with warning lights for electronic slide control or traction control and it says service required. Then driving for few seconds all went off. To my surprise, the steering problems which annoyed me for six months got rectified and steering problem disappeared. I called the agency and they asked me to visit them for a computer check. In fact I won’t go. They ignored my issue from the start and I’m afraid the steering wheel gets the same problem again I just changed my drivers side front sensor this week. I’ve known for a long time it was this sensor as it’s a common fault on the smax and mondeo. It first, it would only appear every now and then and progressed to every time I turned the car on. I believe it’s rust build up on the reluctor ring on the shaft, that damages the sensor. Mines had a pin hole size where it sits close to the ring And signs of wear. Changing the sensor was easier enough, the only small issue was disconnecting the clip on the wiring loom, as it has one of the red locks on it. Quote Link to comment Share on other sites More sharing options...
Rob Mull Posted January 27, 2021 Share Posted January 27, 2021 This has just started on my 17 plate galaxy today. Might be a coincidence but it started after I put it through a roller car wash! Quote Link to comment Share on other sites More sharing options...
Marie g Posted March 15, 2021 Share Posted March 15, 2021 hi I have a 152 Ford mondeo 2.0 diesel. the dash Keeps lighting up with park assist malfunction/steering assist malfunction/abs light, every light really. The indicators stop working when driving abs speedometer. I took it to a Ford garage, they told me to replace the abs which we did but the problem is still there. if I turn the car off when the lights are on the dash and then go to turn it back on again it will not start. And might not start for hours and then seems to reset itself. my front rhs tyre pressure sensor is not working. Could this be effecting it?? Any help appreciated as the Ford dealer can’t solve the problem. thanks in advance Quote Link to comment Share on other sites More sharing options...
Meta55 Posted March 17, 2021 Share Posted March 17, 2021 I think you have bigger issues other than your abs fault. The car needs to be scanned for fault codes. The tyre pressure monitor won’t stop the car from starting, probably just needs a new battery. Quote Link to comment Share on other sites More sharing options...
Russats Posted April 9, 2021 Share Posted April 9, 2021 On 1/9/2021 at 10:53 PM, Meta55 said: I just changed my drivers side front sensor this week. I’ve known for a long time it was this sensor as it’s a common fault on the smax and mondeo. It first, it would only appear every now and then and progressed to every time I turned the car on. I believe it’s rust build up on the reluctor ring on the shaft, that damages the sensor. Mines had a pin hole size where it sits close to the ring And signs of wear. Changing the sensor was easier enough, the only small issue was disconnecting the clip on the wiring loom, as it has one of the red locks on it. Hello just bought a 66 plate and this issue comes on when I got round a bend, then after a few minutes it goes off again. Could be the seat sensor too on this one do you think? thanks. Russell Quote Link to comment Share on other sites More sharing options...
Meta55 Posted April 12, 2021 Share Posted April 12, 2021 Not sure if you made a spelling mistake ‘seat’. Mines would randomly come and go also but more so when raining. A scan will confirm what sensor has gone faulty but most likely the drivers side front. Quote Link to comment Share on other sites More sharing options...
SmaxDriver Posted April 16, 2021 Share Posted April 16, 2021 I had a similar issue on my 66 smax, with ABS alerting, also the (electric) handbrake would not disenguage, the only way to move the car is to disenguage the handbrake in first few seconds while the car is starting / booting up. Eventally got it to the Ford garage, £500 later they reckon it was down to the battery, machanic sensed a variable / inconsistent voltage coming from the battery. Replaced the batter, all good (for now). Must admit, first time I have heard of a battery stopping the breaking system from working, or a 5 year old battery being so knackered, especially when the car always starts first time without any issue of fault. Smells more like a manufacturing or software fault to me. Quote Link to comment Share on other sites More sharing options...
Russats Posted May 7, 2021 Share Posted May 7, 2021 On 4/16/2021 at 6:05 PM, SmaxDriver said: I had a similar issue on my 66 smax, with ABS alerting, also the (electric) handbrake would not disenguage, the only way to move the car is to disenguage the handbrake in first few seconds while the car is starting / booting up. Eventally got it to the Ford garage, £500 later they reckon it was down to the battery, machanic sensed a variable / inconsistent voltage coming from the battery. Replaced the batter, all good (for now). Must admit, first time I have heard of a battery stopping the breaking system from working, or a 5 year old battery being so knackered, especially when the car always starts first time without any issue of fault. Smells more like a manufacturing or software fault to me. Well, I’ve just bought my 66 plate Galaxy, the previous keeper mentioned it had a new battery. I’m wondering if it’s not up to the job. As my Stop/Start does not work either. After a scan, there are two errors showing. I’m going to fit a new sensor and hope it cures my issue. Quote Link to comment Share on other sites More sharing options...
